I've used the RC Pro 2 with my Mini 4 Pro and had no such issues over a couple of flights.Lately when flying my Mini 4P I keep getting the RTH screen (RTH or LAND) popping up for no reason as I fly. I've used this controller on my Mavic 4P and it doesn't do it on that drone.
Anyone else having this issue?
Thanks for clarifying. Can't help you there, although my prior use of the RC 2 with the Mini 4 Pro had no such issues. Sounds like it might be an issue with your Mini 4 Pro, rather than the RC 2, since the Mavic 4 Pro isn't affected by it. Could also be an issue with a newer RC 2 FW update for the Mavic 4 Pro affecting the Mini 4 Pro installation on it. Good luck in resolving it. Sounds really annoying!I realize now that I wasn’t clear on this message. I’m talking about the RC two not the pro the controller that comes with the mini 4. I use that controller sometimes with my Mavic for pro too so we’re not talking about the RC two pro just a normal RC two.
Recently updated mine and never seen this issue. Only time mine ever does that is when the battery drops to 19% (I think).Thanks for clarifying. Can't help you there, although my prior use of the RC 2 with the Mini 4 Pro had no such issues. Sounds like it might be an issue with your Mini 4 Pro, rather than the RC 2, since the Mavic 4 Pro isn't affected by it. Could also be an issue with a newer RC 2 FW update for the Mavic 4 Pro affecting the Mini 4 Pro installation on it. Good luck in resolving it. Sounds really annoying!
