SD Card Help
Brianeromni
Maryland
I have used my SD Card numerous times in Mavic Air Drone. I now cannot insert card into the drone. Tried forceing it but it just won’t insert. I have read somewhere that others have had this problem. Any help would be helpful.
Regards
Stating the obvious but have you inserted it the correct way up?
Agree. I have found a variability in all of my devices- some are up, some are down, but none are backwards. Be sure the metal contacts go in first, and try up and down. You might also want to try that SD card in another device that uses SD cards such as an Osmo Action Camera, Go Pro, Osmo Pocket 3, etc.
Dale
Regards
Maybe a damaged card?
Dale
Okay. Thanks for the help.
Reactions: Parkerjh
Huey0315
