SD card slot
mkaiser
Okay so I had swapped the 16GB card that came with the Mavic for a sandisk 64GB one and when I tried to swap it, it was kind of stuck I have to wiggle it out from side and it was a breeze.
I thought my slot is faulty but when I put the original card it comes out like a charm! The 64GB is a bit marginally thicker so it kind of gets stuck... anyone else have this?
My other 64GB also gets stuck the same way!!!
Cheers
Yes. Pops partially out when pushed in and pulls right out. It's a SanDisk Extreme 64.
Well mine does a wee bit at times!!! But the 16GB at all times will pop out!!!
There is a slight difference in card thickness, I measured some of mine:
Lexar 16GB 633x (stock) 0.72mm
Toshiba m302 64GB 0.81mm
Samsung EVO 64GB 0.78mm
Dispatcher
