SD Card stops reading temporarily
ccoltmanm
This has happened more than once, but I cannot recreate.
The link goes to a video where you can see my SD card isn’t reading and allowing me to take pictures, and then it does after some time or flipping through camera settings.
Any thoughts?
Have you tryed using a different card.
Need details on the card you are using.
If it was mine and having issues like you are I would use
some Deoxit on a card and install and remove several times
to be sure If I had any buildup of anything in the contact slot.
I try the simple things first .
I use it anyway on all my contacts. Might not be your issue
but won’t hurt to try.
Any thoughts?
I have some reason to believe that cards with the insignia “A2” don’t always work as well as the ones that are “A1” with the Mavics.
This is an observation based on tracking problems ultimately linked to SD cards and not based on any technical reasoning. AKA I don’t know why it happens but it seems to be a trend.
denmaytre
