SD card
360 Guy
DELAWARE, USA
Is there a limit as to how many times an SD card can be formatted and reused.
What are, if any, signs of failure should I be seeing?
TIA
TIA
Amount of times one can be written to varies from card manufacture and card.
As for signs here.
Source:
What follows are nine signs that your SD card may be corrupted and you need SD card recovery, damaged, or otherwise compromised which means that your data is at risk.
1.Missing files
2.A “Cannot Read from the Device” warning is given
3.Initialization failure of the system
4.Memory card error appears when trying to use the card
5.No information appearing on your SD card when you know files should be available
6.A black screen on your camera, making it unable to take pictures
7.Formatting error following insertion of SD card to another device, such as a PC
8.Failure of the re-write occurs
9.CRC error during copying or transfer of data
My two cents, the cards starts to act wonky and you don't know why.
flydeep
