Slewing camera left and right
Berf
USA
Is there any way to slew the camera left and right manually on the Mini 4 Pro? On some of the previous models, like the Air2S, you could hold a finger on the screen and then drag it left and right, but I can't seem to make that work on the M4P.
Perhaps you kind of answered your question in your 1st post? This option isn't available on the mini 3 Pro (or any other of the mini series), so probably not avaliable on the 4 either. The gimbal has quite limited sideways movement, and this is really just to smooth out yaw movement. Other bigger drones generally have much more lateral gimbal movement and this opens the option to have user control of this.
Wow, can't believe no one has an answer to this.
The Mini 4 Pro has no 'slew' function of the gimbal, if it is meant to 'pan' the camera then the ability to yaw the craft makes it redundant. Yawing a Mini is also a 'manual' function and very much controlled, other than a violent/sudden movement as the term 'slew' suggest.
slew
transitive verb
1: to turn (something, such as a telescope or a ship's spar) about a fixed point that is usually the axis
intransitive verb
1: to turn, twist, or swing about : pivot
  • Angry
Reactions: rickmurray1989
tagir
