Strange behavior of gimbal when pointing down after .800
optiplex
hey guys
so after .800 also on .900 sometimes not alot when i press the C1 button on the remote controller the one that tilts the gimbal all the way down, the gimbal sometimes shakes, the entire picture shakes
anyone else experiencing that ???
I suspect pointing down you have more close-by reference points makes it look worse than pointing more forward, I have sometimes thought the same and probably it is harder for it to damp everything out pointing down anyway.
Hard to see how firmware update would have much influence unless the whole Mavic was vibrating more.
no i checked it visually while hovering low, the entire gimbal shakes, untill i point it up again
Weird I would start with changing the props first, there might be a very small defect in one of the props causing a resonance in the bird. Hope you get it sorted
Nabvee
