Check your front propellers to make sure you have the correct ones on the correct motors.Hi can anyone tell me what the fault is with my trusty old Mavic mini?
Also how do I upload a short video of it taking off,
Can you tell from the still if they are on the correct motors. Or do you know how you tell if they are?Check your front propellers to make sure you have the correct ones on the correct motors.
The silver stripes are only on the upper side on the blades... so can't see how that can be possible, unless it's not DJI original.to me it looks like you have the lower left prop upside down.
Yeah... besides that the stripe direction have nothing to do with this. The front left should have a single stripe & the rear right should also have a single stripe... both these are CW rotating props. The double striped ones are CCW rotating & should go on the front right & the rear left.Definitely the lower left is not the same as the others. Look at the direction of the stripes.
ah ok...right.Yeah... besides that the stripe direction have nothing to do with this. The front left should have a single stripe & the rear right should also have a single stripe... both these are CW rotating props. The double striped ones are CCW rotating & should go on the front right & the rear left.
Yes I think the front propeller is the wrong one .Shouldnt the diagonal ones match ?Check your front propellers to make sure you have the correct ones on the correct motors.
Exactly right. See post #7.Yes I think the front propeller is the wrong one .Shouldnt the diagonal ones match ?
We got two people asking questions in this thread, is this for both?There is a section in the manual explaining all this. I suggest grounding your drone until you read it SEVERAL times!!
The only question here is about proper blade installation.We got two people asking questions in this thread, is this for both?
Personally, I'm a pretty poor reader in many ways.
Rod ..
