the heat is on
hewo
Honolulu
wow, summer, solar, black onyx, windless, ....
intelligent flight batteries hotter immediately felt on landing
this is how destruct incepts from, escalated materials temperature, materials, of atoms, highly agitated by thermal excurse, the jarred atoms migrate causing compromised separation that was NOT intended by design. routine checks of the super flat true side of battery indicates if bulging ensues. you must clear the nearly invisible standoff nipples to access this flat surface. if none bulging, contact will not wobble, flat to flat.
is temperature readily viewable without menu navigate?
if viewable, will easing up sticks lower the excurse temperature?
Just tap on the battery percentage meter in DJI Go 4 and it will quickly bring up the battery temperature. Don’t worry batteries like to be hot when they are being used. They Key is to cool them after flight and to make sure they stay cool when storing them. Also make sure they are room temperature before charging them for best results.
Just tap on the battery percentage meter in DJI Go 4 and it will quickly bring up the battery temperature. Don’t worry batteries like to be hot when they are being used. They Key is to cool them after flight and to make sure they stay cool when storing them. Also make sure they are room temperature before changing them for best results.
[URL/unfurl="true"]https://1drv.ms/v/s!AoM6q_IWPt1EkQRn1QeGPemv8NLq[/URL]
Got it, toggling ease, great perk, here's quite hot battery [email protected], close call, no connection, autonomous rth, blind enabled to fuel boost, sticks all desensitized, the 4k moves by itself, because of ac volts field?
fisterc
