Tracking Not Working in FW Update v01.08.00.20
MRomine
Anyone else seeing this?
I can not get my Osmo Pocket to track in the video mode in either AFC or AFS. I can not get it to tract a slow moving object nor will it lock onto a sationary object while I move the OP. Is it the update or I am failing with some setting?
Mine is at v01.08.00.20 and face-tracks fine. I had to double-tap over my face on the tiny screen for it to register but once it did it was rock solid. (For what it's worth, the test was done in 4k/50, manual exp, AFC). I presume the update process to .18 went to the end without hanging?
Reactions: MRomine
Thank you, you said the magical phrase, "double tap". That is what I was failing to do. So call this user error, goofy user error. I checked and double checked everything and could not figure it out. Single tap does not work. Thanks again for the reminder.
cloven_combine
