- Joined
- Feb 6, 2019
- Messages
- 360
- Reactions
- 367
It looks like you had a control problem after you flew under the bridge turned around and came back under, then it looked like you were having a hard time controlling the AC for a bit. If this was the case it could be you got some compass interference from all the steel I beams in the bridge. I did the same thing and when I turn back under the bridge my AC went crazy and crashed into the trees on the river bank.
I think its the coding for negative altitude . I believe dji has a glitch . A few weeks ago I saw a video of this kid on top a water fall filming his friends jump off . he flew the AC about >-10ft or so and it executed Auto Land in the water.
as soon as i go mine over dry land i noticed the back light was Red so i though id land in back up on the dock , as i increased the altitude the light turned green . so i tested it . down red up green down red up green . after this I flew without trouble for another 20 min at about 90ft
I think its called moonlit graveyardWhat was the music?
Its a Mavic Air . I plan on doing some testing in a safer place this weekendSar104 flies in negative altitude all the time with no problems. I have a few time with my M2P and had no issue. No idea what you are flying though so hard to compare.
