If you hold your finger on the screen long enough.... it will lock and show you a lock symbol.I am not able to lock AE when shooting videos with my Air 2S.
MA2 317" data-source="post: 1387771" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">I know on the last version of DJI Fly spot exposure was broken.... it was finally fixed in the last update. It is possible the two problems are related as its pretty much the same touch on the screen that triggers them. The length of time I hold the screen is the only difference between exposing for a subject and locking exposure on the same spot.I thought so too but couldn't get it to work.
I do remember that popping up in the past by tapping the screen.
I tried and got control of the gimbal to pan / tilt the camera.
MA2 317" data-source="post: 1387749" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">Hello from the Crossroads of America geekone.
I don't have the MA2s, but since we're using the same app, check the custom setting(s) about the Fn button at the top left of the controller.
You have to chose what the button function does from the list so you're limited to only two options.
Welcome to the Forum.![]()
MA2 317" data-source="post: 1387749" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">Hi MA2 317, and thank you!Hello from the Crossroads of America geekone.
That'll do the trick, I guess.Use manual mode (or PRO mode) to set the exposure and it will stay the same. Automatic by it's very definition means the machine is adapting the exposure to the lighting conditions.
