rather than making assumptions, check what the resolution actually was.I was recording in lower resolution
Are you sure about the file size?but why did I have 3 files instead on one file?
Yes -- I'm sure about the file sizes! They're exactly 108MB, 108MB and 98.1MB in size. I've already played around with the resolution, so don't know where it was set -- but doesn't it make sense that it was a lower resolution! The resulting video's also appear to be a lower resolution than I want!Are you sure about the file size?
There is a file size limitation, but it's closer to 4GB and files get split if you shoot for longer.
Reducing the resolution is one way to have files run for longer.
In >10 years here, I've seen a hundred or more enquiries about the filesize limitation, but nothing about a time limitation.I shot the video continuously and I understand about the limit of the 4GB file size but this looks more like the files are time limited rather than size limited! Is that possible?
