As titled I have a vision system error & I am wondering if anyone has a solution before I have to send it back to dji.
It's a full replament unit from dji & I had this error out of the box.
It seems to be intermittent because when I first tested it outside it was fine so I though nothing of it but the error came back the next day.
I have tried all the usual stuff with the help of dji support which was refresh the firmware, calibrate vision sensors in dji assistant 2, re calibrated compass & imu.
All of this went as expected so I tested again to still have the error but it did disappear when I turned the mavic off then on & I managed a faultless 20 minute flight.
I then went to test it again later on & surely enough the error came back.
I have already opened an escalated repair but if it is something I could maybe fix that would be good, I didnt want to be without it over Christmas as i had a couple of projects planned but there you go.
The vision system error comes up In red in the top left of the app & it loses the obsticle status graph thing.
Any help appreciated
