Waypoint At Aircraft - Air2s
Ziggy01
Any idea how to drop at Waypoint in Litchi while flying? The "fn" button seems to currently be set st "start mission", whereas it would be great if it simply dropped at waypoint at current position.
I suggest you to read the Help section on the Litchi website.
You can set up to 2 different custom functions, for the C1 (left) and C2 (right) custom keys located on the remote controller.
You can also bind 2 different custom functions to C1 Long press and C2 Long press.
For the Mavic Mini 1 and Mini SE: C1 is the RTH button and C2 is not available. Long press is not supported.
For the Mini 2/Mavic Air 2/Air 2S: single tap on Fn button for C1, double tap on Fn button for C2. Long press is not supported.
For the Spark and Mavic Air: C1 is also called the Fn button.
In addition, for Mavic Pro, Mavic 2 Zoom/Pro or when using the Smart Controller you can bind custom functions to any of the 5 buttons of the 5D joystick.
One option is:
Waypoint at Aircraft (Waypoint): In Waypoint mode, adds a waypoint at the aircraft location. The newly added waypoint will have its altitude, heading and gimbal pitch angle automatically set to the current aircraft altitude, heading and gimbal pitch angle.
Reactions: DougMcC
Yeah, thanks.
I found it, but of course I can't delete the OP.
But thanks anyway.
knewgrass
