Waypoints aren't very precise
Bad Santa
I have been playing with waypoints.
One of the things I was trying to do was to navigate within a 20' circle between two trees.
To do this, I set 4 way points. Two in front of the tree line to line it up. One in the middle of the tree line, and one about a dozen feet after the tree line.
What I found out is the drone could be more than 10 feet off in any direction. One of the runs the drone was almost 30 feet off the ground and another found ground interference.
There were zero successful missions despite me setting this up 5 times.
I also had a situation where one of the points was over 40 feet from an obstacle but when I ran the mission it came up with interference on that obstacle. The drone came to a dead stop since it was so close to the obstacle.
Is this normal for waypoint missions or is there something I should be doing to hone it down more?
Are you familiar with Bezier curves and B-splines ? 'Cos that's what way points are doing. They take the straight lines between positions you input at the planning stage, and transform them into B--spline control points , generating a smooth curved line that averages / interpolates between the start, mid and end points it has been given.
The way to get better precision and therefore minimise this effect is to plot more points, closer together, or to actually edit the interpolated spline path to make the travel more linear, which I think I have read is possible in one of the path edit screens ?
Yes, that's what I did to go between the trees.
I stopped exactly in front of the opening and set a waypoint. Then moved forward a few feet and set another. Then directly between them and set another and then a dozen feet past and set another.
At the first of those four waypoints, it gave interference.
Wreckochet
