Weird auto land
droneguy91
San Francisco Bay Area
DJI Go4 was screwing up with me after the latest firmware update. I kept setting my RTH altitude to 110f but kept climbing to 364ft. I ended up deleting the the app and reinstalling which seemed to fix the issue. Anyways, I had a pretty bizarre 1.5 minute flight today.
I had just got done flying over the new Apple Park campus in Cupertino, CA. I flew for about 4 batteries and since the app was being weird, I reinstalled and did just one follow up flight to ensure that the RTH height issue was fixed and I believe it was. I took off at 16% battery life and flew up to 308 feet and a distance of 325ft. I hit RTH and all of a sudden the bird started landing on its own and I had to cancel the RTH. I believe I entered critical low battery mode at that point but it clearly had enough juice to travel 325 feet back home to me. When an RTH is hit on the controller/app and you are in Critical low battery shouldn't it follow through with my request and attempt to RTH?
I have attached the event logs to this. Hoping to see what might have caused this.
Thanks!
I have a similar situation with your low battery RTH situation
Here's mine
Ipad mini 4 with DJIgo4 4.1
Firmware .0700
Was happily honing my MP flying skill on an empty land
My MP was 10m away and 1m from the ground until 18% battery
A notification pop up "battery only enough to fly home", "fly home?"
I decline
It suddenly land eratically
After it hit the ground and some grass around it , I commence emergency stop out of reflex from my controller
Luckily it was only 1m from the ground, so nothing bad happen
I tried to initiate "battery only enough to fly home" scenario the 2nd time
Then "decline", my MP didnt land until battery is critically low
Here's mine
Firmware .0700
I decline
Wonder if there's an issue with Firmware .0700
So now it will auto land at 16 percent?
Yes ......... this is a major upset to some Mavic owners ..... DJI never tolled anyone ..... You can thank them
This was or still is a Topic over at the DJI Mavic Forum it also reduces the 27min flight time DJI advertises
Reactions: Huddy
Thanks for the reply
I do realize that 27min is under "conditioned circumstances" as stated on their web Mavic – Specs, FAQ, Tutorials and Downloads next to it's max flight time
Constant 15.5mph with 0 wind
So what is the new max flight time now?
From what I understand DJI raised the EM landing Threshold from 10% EM to16% This is why your Bird was landing
But that still doesnt explain why my MP had a hard landing
And in the 2nd attempt, my MP was landing smoothly
are these thresholds not configurable? I thought they were in .600?
The op was on FW .700, that's when Owners started posting complaints about it.... it is configurable just not below 16% This is when all the bells and whistles start to go off !!
Perlytes
