Weird Gimbal movement
redserv
hi guys I was checking my last flight on my Crystal sky monitor and for got to mention that in mid flight I got some weird random gimbal issues as I was flying. I know the sun was quiet bright, but from this video I don't think it was shinning directly into the lens. any idea what could have caused this? thanks in advance.
What SD card are you using?
hello Brett thank you for taking the time to help. I am using Scandisk Extreme Pro 64GB. I should also mention that is video cache footage that I took off my crystal sky monitor.
I've had those before, what I do is to first bring it back home and hover at 1m, then do a gimbal calibration, I would, just to be sure, land the drone and restart it
Yes thank you Gizmo. I did exactly what you said at the time. I flew back to home point and restarted and it was all good. Think I will do a gimbal calibration before my next flight tomorrow.
I had the same experience yesterday. After trying all the same things I landed did a complete shutdown and start up and it’s working fine.
My gimbal did act slightly different. It suddenly went to a full up position and would not go down below -10 degrees.
I did perform a gimbal calibration and it was successful. I will just monitor the situation.
vagator
