WHAT book?
Paul Harvey
Tucson, AZ
In order to refresh my "Currency" for my Part 107 I have to take an "open book" test. But I can't find anywhere where it tells you what book it is. Does anyone know?
Thanks
Thanks
It's anything reference you can round up. You're on your own taking the test and can refer to any publications, books, or online resources. You're required to score 100% correct on 45 questions, but there are opportunities to review and correct any wrong answers.
The FAA Part 107 study guides are good for refamiliarizing yourself with the material before the test.
Thanks
To take the recurrency training, make an account at FAASafety.gov. Then take the training course Part 107 Small Uas RecurrentCourse Number ALC677. THis is for if you do not have a Part 61. If you have a Part 61 you take the course with the same name but it will have Part 61 added in the name.
If is more training than a test. If you get things wrong it makes you go back and change them.
You do not need a book since the interactive training makes you watch modules and then take in session quizzes.
Exactly this !
As mentioned, you take the ALC-677 online. It takes about two hours, there are quiz questions after each section and then it's a 45 question multiple choice final you have to complete in a single 90 minute max session. I just did mine last week. The exam was easy, I did not have to go back and reference anything, I did it in less than 15 minutes and got 100%. The questions give you three choices so it's pretty easy to do a process of elimination if you are unsure of a question or two and come up with the logical right answer. Once successfully completed, you can download and print your recurrent certificate.
kholik ibnu
