what happend here?
msenjur
did some sailboat recording. video starts with original recording start... after the shaking is passed, drone was acting normal...
It looks to me like your gimbal went through the startup routine...
It's a known issue. LOTS of threads on it, and DJI has never been able to fix it. Some think it has to do with a bad ribbon cable, others think it is related to the SD Card. Search on things like Gimbal Reset, Gimbal Freak-Out, etc...
LP
ok then... i belive it is nothing to worry about. Drone wont fall out of sky because of that...
Nope. It will just mess up your footage. One easy thing to try is to pick up a recommended SD card. There are a significant number of posts that seem to suggest that the SD card write speed and the 4GB FAT32 cut limit is somehow causing this. Look here for recommended cards: DJI Mavic Pro Accessories & Tips | Mavic Help
LP
The first few times it happens to you...You will freak out for sure lol. But it's okay it happens for no real reason sometimes.
matthewlogan
