What settings will see a strobe light
njxc500
Hello,
Im using my drone to identify a tower from 1 to 6 miles away, and in most cases i can see it well, especially with the zoom feature.
However, it would be helpful if i could see the strobe light at the top.
Are there any particular settings that could help with that, the auto settings don't seem to work for this.
Any ideas?
Thx
So what you are saying is:
As you fly towards the tower in the distance you can see its silhouette and that helps with positioning , but you would like to see the strobe light emanating from the tower itself?
If this is correct one can adjust the exposure value by using the small 5 way switch on the remote controller to increase the exposure value. This should allow more light into the sensor and make the strobe viewable. You can also adjust the ISO to help bring in more light. Adjusting it would require switching to Manual Mode versus Auto
Try shooting 24 frame rate so you can keep the iso as low as possible. Use tripod mode to make the video extra smooth.
genoavoles
