What you think, blemish's
dirkclod
Amory , MS
Just noticed this morning. Never crashed.
What would you do ?
Just keep on it or contact them about it. Flys fine.
Thanks
DC
Another user with that issue unless you've posted this before. Same exact spot too. The Mavic shoulder bag rubbed on my batteries and discolored it a bit on the edge. Windex and a paper towel did the trick. You can try that. I'd only use warm water and a towel maybe microfiber for blades and everything else.
Reactions: dirkclod
No bother really I had just never seen it then after reading
Ksull's post I looked in my bag and sure enough there was something in a pocket for it to rub against.
Return it for a blemish, I think not . The beginning of a crack , yes and thanks for the advise .
Thanks ksull for the tip . Most of it came out :)
Reactions: ksull72487
Yeah same thing and mark on the edge of my battery from the bag. I may try to take warm water and clean the bag out. There could be some machine oils left over.
Reactions: trs80tim
Well I just wasn't thinking and here's what did it
Mavic usually more to the left when I go. I have those zippered
Cases on the way so that will eliminate that problem ;)
When I first saw that was this morning coming in from flying
And after I caught it the sun hit it just right and thougt crap...
A crack :eek:
Coming from the phantom forum I have seen so much of that I just
assumed. Thanks again.
View attachment 6028 View attachment 6029
A crack :eek:
Yeah the sleeve is a good buy even with a bag especially at $7. I'll be getting one as well. Otherwise the foam case is best.
Case would be best but am used to this 511 over the shoulder Tote . These are what's on that slow boat.
IMG_7504.JPG They should work inside my bag . :)
View attachment 6031 They should work inside my bag . :)
Yeah those look very solid. Joysticks look secure. I thought about using a case like that for the remote in my DJI shoulder bag. The shoulder bag is tight puts pressure on the sticks. I bought the lock for now. But yeah I don't think you'll have any issues with that. I agree the strap is needed too. The cases are nice but not good for portability. I walked 4 miles in the forest preserves with the shoulder bag, pulled out the Mavic and flew. For awhile I didn't know I had the bag on me. For this type of drone especially if your hauling it it'll be hard to use a case. What you got there is a good option inside your bag although.
Reactions: dirkclod
Kazetta
