Why does my video recording keep turning off
Jonny_Pain
Mavic Pro - my video recording just randomly shuts off when flying and recording. Any ideas why? Some times it 30 seconds some times up to a minute and a half.
Thanks
4gb limit in the system may be the issue. Try a search on that subject.
Have you tried a different SD card?
Reactions: Capt KO
I've found that it is the speed of the card. Also, not all cards are created equal. An off brand card may claim to be a certain speed, but it might be slower under load.
If you are recording in 4K try changing to 1080 at a lower fps and see if this solves the problem. If so, then it is most likely the speed of the card you are using.
Reactions: Capt KO
I had the same issue. Card replacement fixed the problem. Do not buy cheap cards in Chinese e-shops.
NunoMenezes
