FCC mode on Mavic 2 Pro possible?
you need a Developer account at Apple to sign the patched .ipa
Apple Developer
if you use the free account you need to sign the app every week.
I confirm that this technique does not work.I just created a developer account on Apple, and when I connect to SuperImpactor and I enter my credentials, I have an error message that says: The underlying connection has been closed: An unexpected error was made while sending. I think nobody at the moment is able to switch to Fcc mode
I created a free Apple developer account, with Superimpactor I installed on my iPhone X the last frida hacked version of DJI GO 4 (4.3.2) and I copied the last version of tweak.js in his directory. Everything went well and the app apparently works. The problem is that... there is no difference when I force FCC mode. In FCC mode the 4km signal threshold should be between -90 and -100 dBm. On the contrary it remain between -100 and -110 dBm as in CE mode. Is it a problem of the last frida version of DJI GO 4? or the tweaked app doesn't work with MAVIC 2? or have I done something wrong?
Reactions: therealalex21
I already said, for the moment it's just impossible. I inquired with Dubois specialist and they told me that for now it does not work on android and IPhone. the technicians work on it.
That's why no one shows a clear video tutorial or we see how it works, simply because nothing is working now. It should happen but not before 2 or 3 months
I already said, for the moment it's just impossible. I inquired with specialist and they told me that for now it does not work on android and IPhone. the technicians work on it.
What do you mean with “impossible”? Installing the IPA file or having it forcing FCC? Is it possibile ti install the app, ad you can see in the attached pictures... but it doesen’t workIMG_2672.JPGIMG_2673.JPGIMG_2674.JPG
IMG_6630.PNGthis is running in FCC-mode or what? patched .ipa DJI Go 4.2.22 signed and installed on iPhone 7 iOS 11.3.1 without Jailbreak.
OK... IT'S POSSIBLE !
You have to install the patched .ipa DJI Go 4.2.22 (this version, not the last one) side by side with the last stock version 4.3.x.
Switch on the bird and start the patched app. At the tweak prompt set FCC mode, boost or 32 channels and go to the fly screen. DJI Go 4.2.22 was the last version before MAVIC 2 launch so it can't manage it. It will say that the bird is disconnected, the gimbal has errors and probably will not show any image. No problem: exit the app and start the stock version and... the magic is still there! Check in HD section and you can see that the signal thresholds of 1km and 4km are at FCC level. I already have to try it "on the field" but it seems working well.
Finally, Azuréen, it seems that...
FCC mode on Mavic 2 Pro IS possible !
Hello
I have an ipad mini 4 with ios 11.4.1 how can i bring this .ipa to my ipad
Yesterday i tried it with Superimpactor and i only get " install Result : install error"
Be advised that the signature of the app will last 1 week. Then you have to revoce the certificate and reload the app. The best way is subscribe for the Apple Developer Program (100 USD per year) and the signature will last till your subscription.
By the way... I tested it and it works !!! I'm flying FCC in Rome, Italy, Europe and non more disconnections! The signal is strong and stable.
Reactions: pelagic_one
just now tested with my Ipad Pro 10" and Mavic 2 Zoom... works like a charm in Italy (S. Benedetto Tr.), with a lot wifi interference... now I have the radio power I need and can say waaoooo... can "push the stick" up to near 2km around, where I remember with the fcc Mavic Pro (1) was impossible to go... I'm impressed!
I think too that at Dji they should let the users decide whether or not activate the fcc booster... we pay a lot for this Mavic and why should we have such heavy limitations?
Reactions: RedIce
deepdark
