Unfortunately they do not have any focus adjustment. Depending on your vision you can use the inserts mention by Philius. You can get them directly from DJI or from focus fixers. If your vision is needs a more complex correction you can go a bit farther and get some custom made inserts made to your prescription. I have some from a company called RHO-Lens and they work really good for me.
well I have already reported in another thread, this is not a vision problem. IT IS A PROBLEM WITH THE PRODUCT.
I tested friends googles and his unit has 20% better focus.
How do you quantify focus?
Are we supposed to be psychic and know what you have posted elsewhere?
What answers did you get in the other thread? Was it suggested that perhaps one pair of these goggles has inserts fitted by any chance? Or that one pair might be damaged?
You asked how you adjust the focus, you got the same answer from two people, that might suggest something to you.
Yes I agree with you and I apologize for not being clear enough. Now , however others know that this cold be a device issue.
No the other davice has no modifications and no inserts. It is as plain as factory made it.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
