Active Track not working at high altitude.
Ridermarra
Hi guys,
I have been following friends ski touring up a mountain i followed them till 400m from takeoff point, i was really close to the subject, but DJI go 4 displays, object too high.
Is this intended in the drones limitations? Has somebody experienced the same?
Footage Link:
Hi guys,
Yes, the limit of 400m above the take-off point is intended in the drones limitations.
Yes, a LOT of other people have experienced the same.
You could start another (boring) conversation about why this limit shouldn't exist, but really it has all been said before, time and time again. The limit exists, and it's all in the software, as I believe that DJI have said the aircraft's actual maximum flying height above sea level is 'very high' (perhaps 50,000ft, I don't recall exactly).
If you want to read what has been said before I suggest you search the forum. I can't give you any direct links to previous threads, mainly because I'm not interested. All I'm doing here is saying, 'there is nothing wrong, your aircraft is behaving as it is designed to behave'.
You may not find this comforting :)
Regards
Reactions: Bunny Too
Regards
I do not want to start any argument on dji. if it works till 400m next time i'll climb higher with the take off point.
Thanks
jlhdez
