Active Track Trace Height Adjustment?
rkruz3
CA
Whenever I've used Active Track to Trace, it won't activate and I get a message on the controller that I need to raise the altitude to use Active Track Trace. I think to something like 65 feet.
When I watch videos of people doing Active Track reviews and whatnot the height can be not far above head height.
Is there a safety setting or something I can change to lower the height at which Active Track Trace will run?
Thank you!.
Depends on a subject you are tracking. For tracking a car it requires more height otherways it wont lock to a target. For tracking peoples it is satisfied with just lets say 1 meter from the floor.
I've found that it takes about 15 feet to activate but then it will continue to work much lower depending on the distance.
jacjes
