Zdude70
- Joined
- Jan 30, 2018
- Messages
- 17
- Reactions
- 9
- Age
- 53
Flex Seal in a spray can!The skin works also as a protection ! And you can easily remove it and put another one ! I think it's better to spray your Mavic !
When flying high in the air I think its more visible stock color... but when flying low I can see my mavic better for sure. Never had problems with birds no matter what color I had it... so I can't comment on that. The kit I bought had decals for the bottom as well.
Bottom line is... Make it yours!
Does it show up better in the distance than the stock grey?
Try using a heatgun on Low setting. Some skins need the heat to set them in place.
Heat is not good
I make stickers for a living, the main reason decals don’t stick is because the surface is not clean, you need to use methylated spirit on a lint free cloth or toilet roll will do if you have nothing else clean each area twice with fresh cloth, trust me if it’s cast vinyl (calandered vinyl is thick and is not the best for sharp curved and angles) like most are wraps are your stickers will stick like sh1t to a barn door
