Since the recent update, the Yaw speed seems to have slowed down markedly. Is anyone else having the same problem and what can I do to speed it up somewhat?
Recalibrate the RC in the Control tab in the three-dots menu in DJI Fly.
If that doesn't fix it, in the Advanced Gimbal Settings option in the Control Tab, click on that, and you can adjust the speed and smoothness of Yaw rotation in every flight mode.
7/23/22 Extramely slow yaw speed. After firmware update it the yaw returned to normal. But in less than 5 minutes it was slow again. Then reset RC calibration, again seemed to work fine but after 5 munutes of flying back to slow yaw again. Could it be that my gimbel is messed up?
Check your yaw rotation speed and yaw smoothness settings in Control>Advanced Gimbal Settings. Note that there are different settings for the different flight modes.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
