Another New Guy!
Digital Don
Manteno
I've been doing R/C planes, boats, and cars for a number of years. A couple of years ago I Bought a Mavic Air and use Litchi for waypoint flying. Been an amateur astronomer for 40 years too!
I just discovered Mavic Pilots recently and see there is a wealth of knowledge in these forums.
Looking forward to learning and contributing!
Don
You never mentioned if you have done the Legal stuff, so here it is… And even as an experienced Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . Your Drone weighs more than 250-grams (0.55 pounds) and while you are flying under The Exception for Recreational Flyers, you are still required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live Illinois, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Even though you have flown Drones before, here is some Good Old Fashion Advice…
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Air, including the User Manual.
Fly On and Fly Safe…
Welcome to our forum, from Hauptmann, in Hurst, Texas!
Isn’t it great to have the flexibility of vantage points an aerial camera platform affords? We get shots and videos we could only fantasize about before! I fly a Mavic 2 Pro now, but will soon be upgrading to the Mini 3 Pro.
We have over 150,000 members—many from Illinois--who enjoy helping each other get the most out of our hobby. Most of the questions you'll have will’ve already been addressed, and are easy to search. If you have NEW questions, just ask!
Glad to have you with us!
Rich R (aka Hauptmann)
Welcome to the forum! :)
Don
Welcome, aboard! I'm in Savannah, GA. Hope you find everything you're looking for! Can't wait to see some of your pics!
Dude I'm a Litchi Freak!
Put a watch on this thread.
Post Litchi stuff there.
I think VLM is !
Check them out I will looking for you. :)
Rod ..
Pleopard
