Another new one!
Welcome to the forum! :)
Hello from the Crossroads of America EmGee
Welcome to the Forum. :cool:
I'm down in Falmouth, Cornwall and have a DJI Mini 2. Loving flying it and very impressed by its image clarity
Hope to see some of those images of the Falmouth Lighthouse…
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini 2, including the User Manual.
Fly On and Fly Safe…
Thanks for joining us @ MP @EmGee! Other pilots from Cornwall on here so you definitely have some beautiful places to fly there. Pop into Photos and Video Photo and Video Showcase to check out phots and videos from all over the world.
Keith J
