Hey I'm KJ!
Welcome to the forum! :)
Welcome to the forum, by the way. Hope some of us can be of help.
Since you live in Germany, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mini 2, including the User Manual.
Fly On and Fly Safe…
Wow thanks for all that help, I gave it a good read through!
Welcome to the forum. We look forward to your participation and your view of the world.
573Trader
