I have an Ultrabright
Crystal Sky and have never had an overheating problem, and I live in a desert area where the temperatures are well over 100 degrees F in summer. Early versions of the
Crystal Sky had serious overheating problems, and there is one member of this forum who had his device repaired three times under warranty. Also, some versions of the DJI Go 4 app caused the
Crystal Sky to run much hotter, but this problem seems to have been solved in more recent versions. As a precaution I have programmed one of the function buttons to reduce screen brightness in case of overheating, and I usually operate the
Crystal Sky at half maximum brightness.
The
Crystal Sky has great brightness, but it is a mediocre tablet. I have had the Go 4 app crash several times on the
Crystal Sky which never happens on my newer iPads. I gave up using my iPads in bright sunlight because I live in an “Authorization Zone,” and on the iPad screen I can’t even see the little boxes you need to check to receive authorization.
