Aomway v1 goggles?
Since these goggles have an HDMI port you can use a tablet that has HDMI output like the Nvidia Shield Tablet running DJIGO4 or other application (Lichti) to send everything on the screen of the tablet to the Goggles. You would need a HDMI mini to mini HDMI cable that looks like this
https://www.amazon.com/QVS-1-Meter-Speed-Camera-Cable/dp/B00763TPGE
Lichti also has a FPV mode so you can get that immersive feeling of seeing everything the Mavic see's
The googles seem like a good choice if you want to use them to fly other quads with them as well since they have the diversity antenna's.
So could I use an apple decice, that cable, and 1 Piece Adapter HDMI Cable For Lightning 8Pin to HDMI Digital AV Convert ?
Thats a great question! It Appears that the adapter states that it will support screen mirroring. If thats true and it supports up to 1080 HD then its really worth a try. You will need a cable that also converts the full size HDMI cable output on the adapter to the HDMI adapter on the goggles. Not sure if the connector on the goggles is full size (standard) HDMI connector or the mini size HDMI connector. From the pictures it looks like the full size , but I cannot be sure.
It also states that the goggles using the HDMI input only support up to 720 p which is a lower resolution than what your device using the adapter may be able to output.
Support 3D, HD Port,DVR,Headtracker:
3D Display : Video 3D;HDMI 3D
Audio Output : stereo
Format : NTSC/PAL Auto
HDMIin : 720P
Digital Video Record : Integrated simulation DVR(can record RF and AVIN siginal) , Support 32Gb micro TF card
Video Compression Format : MJPG 30fps
Headtracker : modularization (not included)
There are also reviews on Amazon from customers who indicate they cannot get a crystal clear view of the video source even after making lots of adjustments.
https://www.amazon.com/Aomway-Commander-Diversity-Goggles-Support/dp/B0779Q3T6L#customerReviews
twixer_bear
