Are you better off changing the ISO or shutter speed for the correct exposure?
droobie
Which produces the worst result on the Mavic, increasing the ISO or changing the shutter speed from 180 degree?
For example, you are filming at 30fps, 1/60 shutter speed. It is dim, and you are below exposure. Are you better off increasing the ISO from 100 or decreasing the shutter to less than 1/60. Which produces the best workable result in your footage?
Thanks
Personally I wouldn't go less than 1/60 so I would try upping the ISO to 200 or even 400 but no more or grain will be a major factor.
Change ISO up to 400 only, then srart lowering shutter. Even 1/30 looks fine If movement is kept slow, but anything over 400 is too noisy on this sensor.
deepdark
