- Joined
- May 25, 2017
- Messages
- 8,491
- Reactions
- 7,979
- Age
- 61
OP provided the pack he purchased, and it looks awesome (Aircontact Pro 60+15). Definitely meant for major backpacking excursions or even a through-hike. I'd put the basics for a flight in the 'brain' on top, and chargers etc. in other parts of the pack. If planning on using it often, I won't even case the drone. For a job where I needed to rapidly take multiple photos in succession, I'd kept my Mavic Pro in a cotton bag with a draw string. That's not obviously meant for long term protection, just had to be mindful of my step and pack placement.
View attachment 156932View attachment 156933
This is what I mentioned in post #13, whatever pack / system the OP is wanting for a drone, it must either :
Fit inside the main pack easily accessible.
. . . or
Carry a secondary day pack that clips onto the main pack harness, and can also be used as a day pack for excursions.
I personally would go for a smaller drone (Mini 2 / M3P or such size), in a front fitted day pack, waterproof if possible, and keep it separate.
Using a front fitted pack has this big access advantage, but at the cost of some vision loss directly in front, or mobility issues if climbing on steep trails, stairs etc.
It takes some getting used to carrying on the front, but there are generally 2 types of use for a backpack, when referring to backpacking travel.
Backpacking as in the general travel style, one bag (or a second light small pack as above), lightweight travel, regular travel means like flights, ship, train etc.
Usually, this style of travel uses a soft front load pack, like a suitcase, but has the harness to carry like a backpack.
Backpacking as in backcountry hiking, bushwalking, tramping, etc.
The pack shown above is more for this purpose, as it's harder to load and travel regularly with, but better in foul weather and easier to keep things dry, and more comfortable carrying in rougher conditions, longer distances.
This Deuter pack is quite good capacity, so if the OP travels light, the a small drone setup under the lid might work fine for them.
I just think an M3 will be too large for easy use and carrying capability on either type of trip.
