Think more carefully about what your saying here... GPS/P mode is not a speed.
Are you referring to the maximum speed in P mode? That makes sense, insofar as being internally logically consistent. What you were saying before was like, "what is the color of sweet?"
Okay, that picked apart
, I don't see any reason to assume max speed in P mode is necessarily the most efficient speed in terms of battery time duration. However, this is the wrong metric to pay attention to -- you're interested in best distance efficiency -- i.e. most feet/mAh of remaining charge.
You can make the battery last longer by flying slower, but contrary to intuition this might not get you home. The degenerate example that proves the point is flying at speed 0 -- you'll probably get the most time out of your battery hovering after you reach some destination, but you also will end up going down a long way from home.
Anyway, without going deeper into this rather complicated physics/math problem, people have done controlled experiments with the Mavic to measure this.
Greatest distance one gets on a battery seems to be at around 32-33 mph.
