Bentonville Arkansas area
Seco
Due to health reasons I've been out of commission for the past 2 years but I'm on the rebound and I'm dusting off my like new Mavic Air.
I live in the Bentonville, Ar of NW Arkansas and wondered if there is a drone club in the area. I'm going to fly in the Bella Vista area. I would welcome other drone enthusiasts to join me. Cheers
Greetings and welcome back, from Birmingham Alabama USA, welcome to the forum! We look forward to hearing from you!
Hello from the Crossroads of America Seco.
Welcome to the Forum. :cool:
welcome back to the forum ,glad to hear that your health issues have improved, and you are able to get back into the wonderful hobby of drone flying ,
Welcome back to the forum. Happy to hear your health is better. We look forward to your participation and your view of the world.
Additionally, you might want to check out "Arkansas" in our Local and Regional Discussions Sub Forum…
As an almost New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs more than 250-grams (0.55 pounds), and even while you are flying under The Exception for Recreational Flyers, you are required to register your Drone.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Arkansas, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Air, including the User Manual.
Fly On and Fly Safe…
Great info. Thank you
PilotOne
