New member from the land of 10,000 lakes
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
Since you are studying for your Part 107 License, I am a proud Alumni of the Pilot Institute and the course sure made it easy… So here is a link to get you going…
Since you live in Minnesota, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini 4 Pro, including the User Manual.
Fly On and Fly Safe…
Thanks for all the excellent advice, LT! I appreciate you taking the time to share all of this. Some of it I have done or am doing (e.g. got the Trust, taking Pilot Institue 107 training) and good info and reminders on many others. One things that's great about the internet is forums like these and helpful YouTube videos.
Welcome from Minneapolis, Minnesota. You don’t have to go up north to get great shots/footage. You can do it right in town.
Wonderful shot! Was that taken just recently?
Had dinner at the Nordic Village experience the hotel did this winter on the pool deck. They did it last year as well where they setup a series of cabins and then serve Nordic inspired meals. Was a memorable experience, not sure I would do it again for as expensive as it was.
Thank you. I think this was May of 2022. Was downtown shooting a project and decided to do a little "extra credit".
PilotOne
