Best 64gb SD card?
rayrod354
Kinda confused on which one to get. SanDisk has a few diffeeeent ones and notnsure.
I've always been a SanDisk guy but recently picked up a Samsung. They're very reasonably priced at Best Buy.
Reactions: rayrod354
the scan disk extreme made a considerable difference all this time withe a cheap disc didn,t know what my drone could do
What about lexar??
Highlights:
- 64GB Storage Capacity
- Class 10 / UHS-II
- UHS Speed Class 3 (U3) Compatible
- Max. Read Speed: 150 MB/s
- Min. Write Speed: 30 MB/s
- Downloadable Image Rescue Software
- Includes UHS-II USB Card Reader
Take advantage of ultra-fast data transfer rates and the ability to record Full-HD, 3D, and even 4K video with ease with the U3 compatible 64GB Professional UHS-II microSDXC Memory Card from Lexar. This microSDXC features a data read speed of up to 150 MB/s and minimum write speed of 30 MB/s to ensure you have the necessary bandwidth to record video in a variety of formats, capture RAW images, and view and transfer a variety of files including your multimedia content. This memory card even comes with a UHS-II USB card reader allowing you to insert the card into nearly any USB equipped device without sacrificing the cards data transfer capabilities. For older devices this Lexar microSDXC also features UHS-I and Speed Class 10 compatibility.
High Speed Performance
This microSDXC leverages UHS-II technology (UHS Speed Class 3 (U3)) and provides a read transfer speed up to 1000x (150 MB/s) when used with the included SD UHS-II reader. This gives you the speed and capacity you need to capture, transfer, and share more adventures on the go.
For what?
You’ve posted this in the General Section, so we have no idea what drone you have.
Also, if you are wanting to take photographs only then probably anything will do. Similarly if you are shooting at 1080p at a Lower bitrate, a lesser specked card is sufficient.
If you are wanting 4K at 100mbps then you would need a fast card.
Kia-6098.111
