Best Places to Fly in Sonoma County, CA
Martin9597
SANTA ROSA, California
Hello everyone. I'm new to this group and drone piloting. I have been a photo enthusiast all my life and thought it was time to learn some aerial photo skills. I recently acquired a DJI Mavic Air 2S. I'd welcome any suggestions for picturesque locations in Sonoma County where its ok to fly. It appears that coastal/beach areas are off limits. Can anyone confirm that this is the case for all of Sonoma and Mendocino counties?
@Martin9597 - Welcome to MP! Great to have you.
If you haven't yet, check out the B4UFLY & AirMap apps. They will show you restricted areas (airports, marine preservation areas along the coast, etc) I don't think the whole coast is restricted. Check with the local Parks & Rec regarding flying in parks.
I'm over near Sacramento.
Thanks - I'm using both apps, as well as published regs. from public agencies. The apps are good for identifying federally restricted areas (i.e. FAA, Wildlife & Natural Recourses etc.) but don't seem to include any regional or local ordinances.
Greetings from Birmingham Alabama, welcome to the forum!
Welcome to the forum from the dry lakeless hills of Lake City FL. An irony... I know. If lakes grew here as much as your knowledge will, Lake City would become an ocean. ;)
Welcome again!
As mentioned..check your B4UFly and Aloft.ai for guidance on no flight zones. For state beaches...check the website for each beach and see that rules are posted. From last understanding the superintendent of the beach must post any drone restrictions on their website. Also beware of marine reserrves or sanctuaries as they also usuallu have flight restrictions specified by NOAA.
Reactions: LoudThunder
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in California, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mavic Air 2s, including the User Manual.
Fly On and Fly Safe…
Hey everyone. I got my first drone earlier this week. I've registered it with the FAA, got my TRUST cert and have B4UFly and Aloft.ai. I live in Santa Rosa, right by STS so live within controlled airspace but getting a LAANC was pretty easy up 200ft so I can fly around my house and at the nearby field across the road.
Anything else I should know? Does anyone else still fly around Santa Rosa? I think mostly i'm worried about pissing off one of the neighbors. You never know who might be a Karen.
instaproapk
