I'll have to do a test flight on a moderately sunny day to confirm, but I think I can see my strobes and determine orientation quite a bit further than 1500' away.
I use the same red/green/white leg mounted setup as @Thomas B, but using the Firehouse Strobes that have 4 LEDs per board. I know at night I can see them with enough precision to be able to determine orientation from over two miles away. In daylight I know the distance is significantly reduced, but I think closer to one mile than the 1500' you suggest. That being said, I have never done an actual test to confirm.
@Sd80mac, does your number come from testing?? If so which strobes?? I am not in any way disputing your results, just suggesting my results seem different and trying to understand why...
Thanks,
I do the same thing with one white and one red in the front and a white in the rear. These are the best mounts because they are secure and easy to remove.you can also mount different colours on the rear arms as well as the white ones on the front but the coloured ones are not quite as visible as the white @msinger makes front and rear mounts and the strobon cree ones are very light weight as well not sure if you would have to remove them to fold the rear arms i leave my front ones on and just altered the foam in my case to allow the mav to fit
Recently got a mavic air and have been learning about it overall. One thing I've noticed is keeping track of it, particularly when there's a background beyond the sky is tricky for me.
What are my best options to give the drone more visibility? I was considering the LED prop guards but wasn't sure how that would affect performance.
Any other advice or accessories on ways to improve visibility of the drone while it's flying?
I am not an airline pilot and your comments were very enlightening to me. I’ve started using my DJI racing goggles lately, but as immersive as they are, I still don’t feel comfortable that I know where the drone is in relation to tree branches and other objects. As the googles get better and better perhaps the UAS pilot will feel increasingly as if they are the eyes of the drone. Would two cameras on the drone, one for each eye in the goggles, improve depth perception?The field of view of your ipad or googles of 40 degrees +/- is much less than the fighter pilot or photographer's 180 degrees which is increased when the head is on a swivel as they say. The situational awareness of a pilot is much, much better than the drone pilot's FPV as many threats come at you from the side and not head on. As a airplane pilot the first thing I noticed when I started flying drones was the limited FOV of FPV not to mention the lack of depth perception by having one camera and not the benefit of two eyes. Depending on the drone's mission there are many instances where flying sideways is necessary to get a shot and VLOS is the only thing that might keep you from flying into a tree or other obstacle. This doesn't even take into account the times you temporarily lose LOS especially when transitioning from your screen to the sky.
And this guy did the testing at night... a mile away.
I left my comment in there to ask op to see if he can do testing in daylight. He replied and said he will...
I use strobes and have an Iridescent skin on my MP. It reflects the sun pretty good on sunny days. Something I spin the drone to catch the sun. It helps see it if you lose sight of it for a second like when you have to look down at the controls then back up.
Yes, two cameras on the drone, with two video streams, and one display for each eye would help to some extent, but would still not provide the peripheral vision you would get if you were "in the drone". Not worth the complexity and $$$, IMO. Also, even with stereo vision, your ability to judge distance falls off the further out you go.I am not an airline pilot and your comments were very enlightening to me. I’ve started using my DJI racing goggles lately, but as immersive as they are, I still don’t feel comfortable that I know where the drone is in relation to tree branches and other objects. As the googles get better and better perhaps the UAS pilot will feel increasingly as if they are the eyes of the drone. Would two cameras on the drone, one for each eye in the goggles, improve depth perception?
