Beyond Gimbal Auto Calibration - M2P
Joe Herrera
Georgia
Site
www.engagingfilm.com
I've noticed the horizon is just the slightest bit tilted on my M2P. I have performed the gimbal auto calibration successfully several times, but still seeing a slightly tilted horizon. Should I do a manual gimbal calibration and just live with that setting? Or send to DJI for repait? How much would that cost? Any thoughts please.
have you checked that the gimbal plate is correctly attached to the drone and is hanging level, and also that the gimbal motors are free from debris, try using an air puffer to blow them, or a small vacuum, the hand held type to suck out any thing that might be causing friction
And while your fixing that, do a bit of color correction on your Avatar too ;)
I'm pretty sure you don't actually have the skin tone of a blueberry... :p
Camera Down and Camera up or:-
Download and Install Python on a PC.
Download and install DJI tools
JointCoarse will move the gimbal to its extremities and record the values
LinearHall will then centre the camera between the extremities discovered.
Video Here!
Tools .
1. Download Python
2. pyserial
3. GitHub - o-gs/dji-firmware-tools: Tools for handling firmwares of DJI products, with focus on quadcopters.
GUIDE :
1. Download all tools
2. Install python
3. extract pyserial and dji tools to C:\DJI\
4. Open "command prompt" as administrator
cd C:\DJI\dji-firmware-tools-master
5. Install pyserial using pylon script
cd C:\DJI\dji-firmware-tools-master\pyserial-3.4
python setup.py install
Turn ON Mavic 2 Pro/Zoom
Check which COM port (usually com3) [Right click on This PC; and click on Manage; Device Manager> Ports(COM LPT)
Gimal Calibration
At a command Prompt run
python comm_og_service_tool.py com3 WM240 GimbalCalib Jointcoarse
python comm_og_service_tool.py com3 WM240 GimbalCalib LinearHall
Suilven
