I use Adobe premiere, and just work with my levels and temp....etc I also work with LUTZ, I just started with these but they are proving hugely helpful. If you get a chance just you tube some videos on the subject, they can do a lot better explaining than I can, also applying LUTZ to post will help tremendously, it will literally be a one button fix for a ton of color issues. Also I am not sure if you said you are filming in Dcinelike or not however I find if I film in vivid or true color obviously I get way better results however it will be harder to deal with in post because you are applying a filter essentially that can not be undone later, but my thoughts are if your not doing a whole lot in post anyway who cares, it will look better. The good news is you have your angles and flying style DOWN, doctoring up footage is the easy part, you obviously have what can’t be taught.
