Burst and RAW are compatible?
enriqueiii
Hi, I've tried today some shooting using the burst mode in RAW, and the result was 3 raw files that are equal, they are not with different exposures.
Am I doing something wrong? or the burst mode is not compatible with RAW?
Regards !!
* Sorry if is not the correct category to put this
Thats correct. If you want multiple pictures taken at different exposure values (some more exposed and some less) then you want to choose AEB and set the exposure stops.
This is typically done to stitch the resulting pictures together for HDR photography using a software program like Photomatix.
If in AEB (Auto Exposure Bracketing) It will shot in 3 or 5 pictures of different exposures. Which you can use photomerge in photoshop to merge them by exposure. Also I would HIGHLY recommend dumping the micro SD card that comes with the Mavic and get a high speed one. I do many 5 AEB panoramic ones and waiting on the card really hinders the wait time to the next set of shots. I personally use this https://www.amazon.com/dp/B06XYT37NK/?tag=hcwt-tps-20
