Camera Anti-flicker setting
jamiemink
Weird. Neither my Mavic or my Phantom 3 will allow me to change the anti-flicker value to 60hz in the camera settings. They're both unchangeable at 50hz selected (DJI GO 4 and DJI GO apps, respectably).
Thoughts?
Thoughts?
You have to choose auto on the first page of the camera settings to change the anti flicker. It will not change unless its in auto for some reason..
Reactions: jamiemink
I was having this same issue, so I tried going into auto camera mode, then changed the anti flicker to 60hz, went back to manual mode and it stayed at 60hz, must be a bug.
Reactions: Scapegoat
If it is a bug then it is still there after the .600 update. I was flying recently and noticed mine set to 50hz and that I could not change it to 60hz. Switched to auto mode and I was then able to change the setting to 60hz. Seems backwards to me.
tflys78
