Camera settings
Linny08
Irymple
Hi all, first time posting. Hopefully someone can help. I have just received a secondhand drone. I can’t seem to change the camera settings from auto to manual. Any suggestions? I’ve pressed and slid the M but nothing happens
Thank you in advance
You have to be connected to your aircraft which in these pictures you appear not to be!
A good portion of the settings that are adjustable need to be done with the aircraft powered on, not just the camera settings. Take the time needed to check them all and get familiar with how that all works so you don’t have an issue later. Some settings you will change while flying, and you need to have the ability to find them and modify. There’s a lot to learn. Take your time.
What model drone did you get ? Obviously DJI and most likely one of the Mavics.
As you are probably aware, there is no printed manual supplied, but pdf's are available to download to your device or desktop for referral.
If you go here DJI Mavic Manual | Mavic Help you will find the Mavic fleet.
Worth downloading yours to help you find most operational info.
themirac
