camera won't tilt up
motopokep
Anyone know how to fix this? I read somewhere that if you do a factory reset, it can solve the problem. If that's true, how to do a factory reset on the mavic? The camera tilts all the way down, but when trying to tilt up, will stop dead straight forward. I've done an auto gimbal calibration, and IMU calibration. What else can I try? No crashes, only did 1 short flight so far.
Here's where that setting is located in DJI GO:
Reactions: Portofine
Interestingly, that 30 Degree setting gets disengaged on my MP frequently, so I need to go back and switch it on again, and again ..
Latest firmware/software, no other troubles but this one ..
Any clue?
I think someone reported it gets and stays enabled when you use pano mode so there might be something else rhat disables it..sw updates also mess with your settings, i wish there was an option to save/load config..
I just posted about this same problem. So I guess there is no solution then?
Any clue?
Does yours still do it? Mine does too. Trying to get to the bottom of it but seems no one else but you is having this problem
Colinhayesroberts
