Can I have DJI Assistant 2 "Consumer" v2.1.9 (latest) -and- older v1.1.2 on same computer?
pchaps
USA
I already have the DJI Assistant version 2.1.9 that I used for Air 2s, but now I want to install Assistant v1.1.2 to have ATTI on my Mavic 2 Pro. Can they both reside on the same Win PC (I will only run one at a time), or do I need to install the older version on a different computer?
Just uninstall 2.1.9. Can always reinstall if needed
Reactions: pchaps
Thanks! I use a desktop PC, is it best to use Windows uninstaller or is there a DJI uninstaller?
It’s been a little while since I’ve used Windows but I believe you can uninstall applications from the windows system settings or preferences (whatever they call it)
Don't uninstall anything.
I have
"Assistant 2 for Mavic" version 2.0.14
and
"Assistant 2" version V1.1.2
both on a Windows 10 PC.
I only ever use one at a time but there is no cross talk that I am aware of.
Separate Apps should be OK.
They are installed in C:\Program Files (x86)\DJI Product\
I think the programs are cross platform Apps built using something called electron. Check it out here
Reactions: pchaps
I have
and
Thanks! You saved me from wasted time. Will try it now. Perfect timing!
This is a follow-up to say thanks to everyone and to confirm that I have two versions of DJI Assistant installed on both a Win 10 Pro64 and also an old Win 7 64 computer. I can choose either the old v1.1.2 version or the latest version. Works great! As noted, only run one version at a time. v 1.1.2 has debug mode.
engmarceloacs
