Canadian Rookie
WhiteyJr
Alberta Canada
Hello from Alberta Canada! Long time video editor that just recently started getting into the drone scene. Had a low-quality (cheap) one for the last few years, but recently took the plunge and got myself a Mini 4 Pro (FMC). I've only just started to explore the possibilities of this unit and so far have LOVED it! Its a HUGE upgrade from my previous one. Looking forward to learning lots here.
Welcome to the forum! :)
Since you live in Canada, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mini 4 Pro, including the User Manual.
Fly On and Fly Safe…
Welcome to the hobby.
Useful for seeing where you can fly is the NRC drone tool:
Change your category of operations to "Micro" to see where you can fly your Mini.
I like the Drone Pilot Canada app, which not only gives me access to the NRC map along with things like power lines, but displays NOTAMs as well. Also logs flights and maintenance, keeps crew records, stores documentation, and has customizable checklists. Also does flight plans, although I haven't used that feature yet.
You might want to consider joining the Drone Pilot Association of Canada.
Welcome from Vancouver Canada!
I also recently started droning but have already logged around 100km. My RC Pro controller's gimbal pitch control wheel went bad last month so had to send thr Mavic 3P and the RC Pro in to DJI, but in the meanwhile I got a Mini 4P flymore from Amazon for some testing and fun in the mountains. Mini 4P really impressed me with it's still images quality which is something I wasn't happy at all with Mini 3P that I tested, used and returned earlier this year.
Here's a recent sunset shot with Mini 4P below from the skies above Coquihalla Region in Southwestern BC, while snowshoeing to the top of a mountain.
Thanks everyone for the replies! This is the first time I've shot in D-Log M and have just started playing around with the colour-grading for that. Definitely a lot to learn.
According to my niece (professional filmmaker), the trick with colour grading is to first grade the footage so the colours are neutral, then apply grading to get the 'look' you want. She says a lot of people try to do it all in one step and that only works if you're using the same camera and the lighting didn't change at all during the shoot.
Welcome to the forum from the Rocky Mountains of Colorado! Happy and safe flying!
xa_
